Okla Panhandle | I'll check the overflow line, the new seal was installed with numbers facing out (as JD shop instructed). I tried to get more diagnostic info from JD but in this area this is an "old" tractor and they mainly use software in place of diagnostics and experience. The only reason I went ahead with change was, I was changing belts and had most everything was out of the way anyway. | |
