Northern Indiana | 10,000 is the polygon limit
I have used SMS to view each map, change to grid view, then modify the size of the grids to give as much detail as possible while staying under the limit
The number of polygons is shown in at the bottom right of the screen, labeled as "Count"
mtbfarms - 2/6/2016 22:39
You have to countor the yield map before you can export it. There is a limit to how many polygons can be imported at any one time.
Edited by 4wdaaron 2/7/2016 10:42
