Somerville, Indiana | I can tell you its a quiet handy little feller for its size...the 160B has fuel
parts on the left side of the engine, fuel pump, what Case calls a common rail, and fuel lines...Best way to access these parts are to remove the counter weight which isn't that bad of a job, just heavy, held on by 4 bolts from the bottom...It does have a lot of bucket curl power for its size. | |
