Iowa | You need an Incab module that goes right under the monitor (I have a used one for sale if you need one), harness from the 20/20 to the rowflow, the rowflow module itself (make sure you orient it the same way as one of the options in the setup when you mount it or it won't work properly), harnesses from the rowflow to the clutches 4 clutches per harness like other poster said, and the clutches themselves. There is also a lift switch to tell the monitor when the planter is up and down. I would have to look to remember where and what harness that ties into. I'll try to add a pic of the Incab module, if you need one the email in my profile is good
Edited by BrandonGro 2/5/2016 23:57
(image.jpg)
Attachments ---------------- image.jpg (68KB - 69 downloads)
