Posted 2/4/2016 23:05 (#5089277 - in reply to #5088359) Subject: RE: Changing Viper Pro monitor to Insight
Southern Illinois
Depends. If you find an Insite with the autopilot unlock then you could use the nav2 steering. Otherwise to have integrated steering you are going to need a Versa or Integra and replace the nav2 with a SteerCommand, Geosteer, or Paradyme.
For the spayer system you have to remove the Raven nodes from the system and replace with a DirectCommand kit.
