South Georgia | I have an EZ Guide 500 in my sprayer that I use for guidance and rate & section control. As a cotton and peanut grower, we do a lot of spraying, with multiple passes over each crop. Rather than using a name for the event, I just choose the default name, which has the days date in it. This way if I need to go back and look at a coverage map of something, I know which one is what. Also, if I have to leave a field before it's finished and it happens to be a few days before I can return, the event needed is the last one in the list, I don't have to remember what I called it.
This has worked fine for several years, but last year I had some fields that wouldn't open because I had exceeded the maximum number of events. How do I delete the events? Deleting the coverage logging or summary files doesn't do it. All the past event names still show up under each field.
When this happened last year, I just had to create a new field and make new lines, but this is really not a desirable work-around.
Any of y'all got an idea? I'd sure appreciate it.
Adrian | |
