Dearfield Co. | Watch for bends in the line from the combustion chamber to the pump as well as where ever you have it dump. In 2 of my rentals the condensate line runs in the attic across the house and then down to the washer drain. When it gets cold it wants to mess up---------All of mine in my rentals also seem to be hard on the hot surface ignitor sometimes taking one yearly. When you replace them you have to look close to make sure it is close to the flame sensor or you can also have issues. I have had to bend some to get them closer which I just shake my head at. Hopefully a furnace tech will log on and give you better answers than I can | |
