Search Forums | Classifieds (47) | Skins | Language
changing file format
tedbear
Posted 1/30/2016 08:38 (#5074387 - in reply to #5073819)
Subject: RE: changing file format
Cat33 - 1/29/2016 20:45
Open your file, click "save as", then at the bottom you will see "file name"...you can change the name there if you want. Under that is "save as type" and pick whichever you want to save it as.
The above is true if it is possible to save it in another format. Many times, yes, other times no.
