Southern Illinois | What they added:
Ability to run split screen. Example1 ISO VT unit and guidance / mapping at once.
Example 2- while combining, seeing yield map next to planting map, or fertilizer applied map, or spray map from earlier in the season.
Ability to process real time logging data and show you as you go. Example- real time population / singulation on the coverage map row by row in real time.
Integrated the WiFi adapter, not a separate part, for use with AgFiniti cloud or the AgFiniti apple app. Can transfer processed maps from Incommand to iPad app with WiFi. Can sync several machines at end of day to an iPad without needing and internet connection. App can combine maps from multiple planters or combines for easy review. In the past the logged data needed to get sent first to a SMS PC to be processed.
What they took out
Incommand will no longer work with old Ontrac2 and Ontrac2+ steering units. | |
