Interesting challenge. Basically, you are asking for a RANKIF formula. I'm sure it can be done in a single formula and I found some possibilities (using SUMPRODUCT etc) that I don't have energy to work out tonight. An easy solution I can come up with right now is to have a helper column. So, in column D put this formula: =IF($A$2>A2,"",C2) Then, in column E, put this one: =IF(ISNUMBER(D2),RANK(D2,$D$2:$D$11,0),"") If that doesn't work for you, then I might have more time tomorrow night. |
