Posted 9/21/2015 21:09 (#4801612 - in reply to #4801288) Subject: RE: Internet Dropping Out
Central Nebraska
Check in the network adapter settings to see if your IP address is set to Static or DHCP. If two devices are using the same IP address you will end up with the symptoms you are describing.
