roaming | 69Cat - 8/29/2015 15:51
Have v31.4 and cant find the loads or field / farm in order to make moisture calibration. I have the manual and it looks easy enough but when i go to the cal screen it shows one choice which was wheat from last year in a different field, this years data is not visible.
I have it set for edible beans (doing yellow peas) and my harvest screens show all the correct data with farm/field/load and showing edible beans. Acre and yield counters are ticking along. What step am i missing to be able to correct the moisture displayed to what are bench top unit is saying? Been through the manual a number of times and cant find what step i am missing.
You cannot calibrate the current active harvest load. So once you complete the load you want to use for calibration, you must create a new load or select a different load, before the calibration load will be visible in the calibration screen. |
