| I have a 5310 JD tractor that has a brake problem, the peddles bottom out when engaged but
will come up and work when the peddle is pumped about 2 or 3 times. When the peddle is released
the next time they are touched the peddle has to be pumped again. Are the brakes operated off the
hydraulic system or does it have its own reservoir. The operators manual only says to see dealer.
Thanks for any suggestion on what I may look for. | |
