roaming | Case IH Farmer 12 - 7/31/2015 20:20
I bought a new to me BBI spreader that had a 4400 raven monitor. I put a node on the spreader and am now planning to run it through my pro 700 vt and using a task controller. Problem, the rpm gauge on the vt screen is pegged. Put new bolts for sensor to read on spinner, new weather pack connection at sensor (it was corroded pretty bad), and now new sensor and still no change. What to check next? My bun level sensor is in the same harness and it seems to be working fine. Thanks!
Is there a calibration procedure for the spinner speed sensor? |
