Posted 7/3/2015 19:42 (#4660064 - in reply to #4659409) Subject: RE: Y drop or split the row? Wet planted corn
Charing Cross, Ont.
I won't argue about N movement either, but just an observation from applying 28% on wheat. If you drive to wide on your passes the green stops at the end of the boom. Even if you are only 6 inches wide the wheat in between is yellow. Getting the N close to the roots to me is important
