Search Forums | Classifieds (206) | Skins | Language
AB lines with different equipment sizes
torn
Posted 7/2/2015 21:34 (#4658612 - in reply to #4658544)
Subject: RE: AB lines with different equipment sizes
roaming
cdm975 - 7/2/2015 20:07
So am I just doing some wrong that's a simple fix. I sow with a 40ft drill and have created AB line. Use a USB stick to transfer the AB line to my sprayer which is 100 ft. Why do I have to shift my line when I first start the field?
Your line is generated at a specific place in the field. it doesn't move just because you change implement widths. the line has no idea what your field looks like, where it is in relation to the field, or what you're doing in the field, so you have to tell the system what you're doing and where you need the line to be.
