Posted 7/1/2015 07:04 (#4655568 - in reply to #4655530) Subject: RE: Jd 567 baler density valve
Ne Nebraska
You will have to get the lock ring loose before the larger dial with set screw. Should turn easy if lock ring is loose. May have to hold where it screws into block to get lock ring loose without turning whole thing out. Hope this made sense.
