| I have a 1210 david brown and I am getting a lot of diesel fuel in the crankcase and mixing with the oil. Wondering if anybody has run into this problem and what they did to fix it |
W.C. Mo. | Not sure about your tractor but if it has a mechanical diesel booster pump run off the cam...... |
EC IA | could be the fuel lift pump, or the injection pump drive shaft. first one is easy to do second is not quite as easy. |
middle tn | had a 4430 jd that did that , it had a hole in the injector housing , I was told ,replaced pump |
Elizabethtown,KY | More than likely the injection pump shaft seal. |
| I second the injection pump shaft seal. I had a MF275 tractor do the same thing about 10 or 12 years ago. I had the pump rebuilt and trouble solve. |
thumb of michigan | Low Sulfur Fuel strikes again! |
| Thank you, I think it is the pump seal also
