southern MN | Told it to update Windows, and it found 106 updates.
Went out and sprayed a tank and. Half on the corn, came in and it had done 74 of them.
Watched it a while, did some other stuff, and walked it through several restarts and install sessions.
Finally came up 4+ hours after I started the updates, I had it check and it found 3 additional updates to the first updates.....
Ran through them.....
Whew.
Think I call it set up and done, ready for her.
Sure is something how W8 features all the crud software on the tiles, and anything useful gets tossed to the back, or bottom, in a small tile...... I'm sure it could be switched around different, but out of the box its easy to see what the goal is, try everything that could pry a buck away from you, and never mind trying to do anything useful with the machine.
Paul
Edited by paul the original 6/6/2015 00:11
