roaming | cdm975 - 5/29/2015 09:11
Can someone explain this feature or give an example of where you use it. Thanks
You can use Pause to mark the spot where you leave the field, so you can come back after refueling, lunch, etc. Or if you're talking about Pause while recording a guidance line, the display will pause recording, and then when you resume recording, the display will draw a straight line between the Pause and Resume points. This lets you put a perfectly straight segment into a curved guidance line. |
