| The electrical gremlins are out and about on my sprayer.
Last season, when I would start up machine, alternator would not charge, tach was stuck at 0, and air conditioner would not work. This would last anywhere from 10 minutes to an hour. Then...presto...everything worked the rest of the day. I removed alternator and that checked out fine. Looked for a loose ground somewhere but could not find anything.
Of course dropped the ball and struggling with the same issues this year, plus a couple more. Have put on about 30 hours with same trouble. Today, no air at all. I am also blowing my boom shut-off control 20 amp fuse. If the machine is turned off for a period of time and I start spraying again is when it blows. It does not blow again the rest of the day until the machine sits.
Machine has 3500 hrs and is very rarely outside. The fuse panel has no rust and is spotless.
Any ideas? | |
