“These are the times that try men's souls.” | I like the Prima Tech, but I've had the same problems as you at times. Best solution is to suck the hottest water though them when done using them. I don't take them apart to clean, just hold under the hot water where bottle suction is, and keep pumping it till it comes though. then I will unscrew the plunger and let them air dry and put a little lube on the o-ring. They seem to stay working that way.
I've even bought little bottles of sterile water to run though them when I can't get home to wash them out on a timely basis. I like really like how the Prima gun fits my hands. |
