Ns/Tr co. Ks | Click on the product control tab is in the upper right corner- where it shows your target rate. This will take you to another page that'll either have the low limit tab or another page within this. Based on the size and number of tips you have you'll put in a figure in gal/min so that you'll always have 20 psi. I cheat by just having this page open when I'm spraying and slow til I get down to 20 psi then it'll show how many gpm that is. You'll need to change this value for every different combination of numbers or sizes of tips.
If your sprayer came with tips on it and a low limit not set- your dealer is just as good as most. | |
