Posted 4/26/2015 12:13 (#4538807 - in reply to #4538632) Subject: RE: Db 44 center section height
Tuscola County, MI
Mine is also like that. I think if you put it in the other holes you'll be way too high in the center and won't have enough to travel in the cylinder to lower it all the way to the ground. I believe that done DB 44's run single 455 semi trailer tires that are taller and that's why the other hole is there
