Search Forums | Classifieds (6) | Skins | Language
Bricks loose on outside wall?
JohnW
Posted 4/15/2015 01:42 (#4517291 - in reply to #4516731)
Subject: RE: Bricks loose on outside wall?
NW Washington
I sounds like you have a brick veneer wall and if it is loose from the main stud wall I think it will have to be torn apart fix it. Sounds like the brick ties have failed or were not installed correctly.
Here are some pictures of typical brick veneer wall construction. https://www.google.com/search?q=brick+veneer+wall&espv=2&biw=1920&bi...
