Posted 3/31/2015 09:11 (#4488111 - in reply to #4488013) Subject: RE: Piglet Castration
swMN
side cutter all the way, new stainless steel, do them less than 10 days old, hold the pig upright, with the snout in your arm pit, both back feet in your hand, gently squeeze and the nuts kinda pop out and up, one cut with the cutter 3/4 of the way down the sack, both nuts thru the same cut, lots of times the nuts will just pop right out after you make the cut.
