lulzboat | The best way to do this would be out the port on the back of your FMX is have your cable come out and split into two connectors one that will hook into the radar connection for your rawson and the other connector will connect into the radar connection for you KPMII monitor. Another easier way to do all of this is get rid of your accu-rate control box and KPMII monitor and install field IQ onto your planter then you can control everything through your FMX display. | |
