Posted 3/2/2015 12:04 (#4425285 - in reply to #4424136) Subject: RE: Can i do Variable rate with Seedstar 1 (emulator) on 2630
Ec Indiana
You should be able to, not real sure what an emulator is. We ran a seed star 1 1910 for yrs with variable rate through the brown box and a 2600 or 2630 as a dual display. U will put the Rx on to the 2630 and set the brown box to run off of the map based setting on the variable rate set up screen.
