| The type of ground makes a big difference in rent. Is it precision leveled or do the levees run all over the field? Is it ground that will hold water or is it sandy ground that you will have to leave the pump on 24 hours a day, 7 days a week. I have some of both. My heavy, level ground takes about one-half the water as the sandy field does. Will you store the rice in your grain bin at your expense or haul it to a mill out of the field. Typical rent in my area is 25% for average rice ground and 30% top of the line ground. | |
