WC Wisconsin | Is it cheaper parts but in the last two years I've had to change 5-6 engine thermostats due to sticking shut or now sticking open (no "warm" heat in cab). I changed two in tractors (JD) that had probably 10,000 hrs (or more) each with no issues. We overhauled both engines so time for a change. Those don't count. All my newer equipment 2005-newer are the ones that have had the thermostat problems. I change coolant often enough so there isn't any problems there. | |
