Posted 1/28/2015 21:15 (#4346102) Subject: 4455 front crank seal replacement question.
West Central Wisconsin
Looking at JDparts.com it appears the front crank seal installs from the inside of the front cover, requiring the cover to be removed. Is this correct? Does the front housing come off without removing the hyd pump support? Plan on replacing hyd. pump couplers/cushion but wondering if the damper should be replaced,(6,500 hrs.)? Thanks. Joe
