Posted 1/28/2015 20:12 (#4345843 - in reply to #4345663) Subject: RE: 40 and 50 series jd tractor lights
South Central Kansas
No only the inside front are double if I remember correctly. Outer fronts are low beam only but stay on when high beams are on, inside fronts have both, upper rear lights are on only on high, and lower rear are on both on high and low. I believe this is correct.
