Claremont,MN | One other benefit that no one else does is draw the coverage map based on actual seed placement and not on when a lift switch says it is planting. With any other system if you shut the vacuum pressure off and pretend to plant it will draw a coverage map like it was actually planting. with the 20/20 if it doesn't see seed from the seed tube sensors it will not draw a coverage map. | |
