| Call Eric at Grand Island Store Ag Express
Configure the DJ module as Blockage only. You can mess with & put a rate or population numbers in there,,, but if your using a lot of urea,, you'll not like it & your bar graph will be all over the place. Setting off high pop/low pop alarms. Now if ur using a lot of potash/map,, the sensors can "See" that better & you will get a good reading. 95% of the time I have my system set to blockage only.
I have this system running on a 2630. But my buddy has same set up on an Integra. | |
