Classifieds (6)
Would a belt idler pulley work ridgid mounted?
Machinery Talk
Wheat77
11/23/2014 19:28 (#4197043 - in reply to #4197032)
RE: Would a belt idler pulley work ridgid mounted?
You should be able to do that, but do recognize you need the proper speed on the generator,
to output the proper voltage.
I am wondering if you are simply trying to use the 1000 PTO speed on the tractor?
If so, just idle down, and check your output carefully. Get your tester out and meter things.
mulligan
: 11/23/2014 19:23
Wheat77
: 11/23/2014 19:28
mulligan
: 11/23/2014 19:35
nhermanson
: 11/23/2014 19:47
E718
: 11/23/2014 19:36
Wheat77
: 11/23/2014 19:40
