Ladoga, IN, United States, North America, Earth | The way to do that in SMS is to do a simple analysis and scale the data. You can scale by which ever measured attribute you want. You'll need to right click on the harvest instance data to and choose "add simple analysis". The scale factor will start out at 1. Take your "actual weight÷monitor weight" and that will be your new scale factor.
Another way to do it is put in a manual entry which will not change your maps. |
