Posted 11/22/2014 23:38 (#4195249 - in reply to #4195121) Subject: RE: Raven yaw sensor?
Butterfield, MN
I'd even say that if it holds outside of a range of -1 to 1 that it's bad with yaw sensor on the long box. Not sure if it's worth trying to send it in to get it repaired or just to go ahead and replace it.
It always used to be that -2 to 2 was the range on the 3D nodes, but not sure if that's even a good rule of thumb anymore with the newer RTK capable nodes.
