NE Indiana | Is there a software that allows you to create small plot prescriptions I know agleader has the plot prescription module but that is more for specific for plot planters. I want to create plots that are directly aligned with AB lines in the field so there is no measuring on the software to get the plots in the correct plots. Most all of these plots would be 30ft wide and planted with a 15 ft planter. thanks for any imformation even if there was a way to grid the field to match up with the ab lines and then make the prescription off of that | |
