Appomattox/Fredericksburg, VA | How is the mass flow sensor shot? I think, not positive, but think that you have to have moisture to have mass flow not the way he said. Do you have a reading for clean grain elevator speed? Need that for the mass flow to work. Might just be a wiring problem. Make sure the 3 wires doing to the mass flow are still intact. Mine would intermittently show yield then not and turned out the previous owner had the 3 wires break and they just wove them together instead of soldering. I bypassed the harness and ran the 3 wires directly to the connector at the moisture sensor to isolate the problem. |
