roaming | Case IH Farmer 12 - 10/27/2014 04:46
Found it, it wasnt enabled. Is the TC task the same task as my 700 has or is it different? Also the TC implement is greyed out but I am not connected to my toolbar. I assume when I hook up to it, I will be able to set it up?
Correct. ISOBUS requires the implement be present, so until the implement is connected, you can't do anything (your VT screen will also be empty). You'll be able to set up both the VT and TC once you hook up the implement. |
