ne nebraska | pulling a brent 670 with mine. I feel ok with it, but you can wrap a chain around the two bottom arms of the three point and loop it under the drawbar if you are worried about it. set it just so when the three point is raised all the way that it just puts a little pressure on the draw bar, be very careful not to get too tight........ I run mine without the chain, don't as the the three point occasionally creeps down overnight and when you start the tractor and the chain has a twist or something in it, guess what happens..... | |
