NW Iowa | If you are just trying to turn off the hydraulic motors this isn't going to work very well. You're going to get alarms about the drives not turning whenever the clutch module would stop the drives. You would need some kind of relay setup to the drive motor and it seems like it could get pretty complicated.
If you go with just the hydraulic rate control module you will not get AutoSwath control. You have to have the clutch control module to turn off planter sections with autoswath. | |
