SESD | Kind of a follow up to my post below.
Tell me if I have everything straight here.
575lexion. No hydraulic block for steering, but does have autopilot button on stick. Wired for Agleader.
I am going to put an ontrac2+ in it with an Integra. I have Outback 220/221 RTK for the receivers. I also have a 220 to run on omnistar, would that be good enough? Planting is on RTK.
Will everything work fine here? Am I correct that the Truesight will not be able to be used? I plant with the RTK receivers, so should I be OK there?
Will everything work fine on the grain monitoring side of things? Yeild, moisture, mapping.
Anything I'm missing?
Thanks guys.
