Posted 9/18/2014 08:47 (#4080546 - in reply to #4079510) Subject: RE: 4430 command pro accuboom malfunction
Sounds like a CAN bus issue.
Does the machine have autofold or autoboom? if so are they staying online?
check and make sure you have a CAN terminator installed near the accuboom node or the autoboom node. (if equipped) it should be a three pin triangle deutsch connector.
