Northeast Nebraska | In apex, I went to "file" and then "export map" and then I chose "batch export" I then chose "export operation data" and set the export filter to "by operation" and then chose "seeding"
Then I went through the client/farm/field tree and just chose 2014 for the year. Under the export options, the "calibrate data" was the only box checked, which was by default. For file type I chose the SHP file.
If I did something wrong please correct me | |
