Posted 8/29/2014 06:18 (#4044425 - in reply to #4043847) Subject: RE: Any way to measure planter down pressure with just a voltmeter
http://www.redlion.net/Products/DigitalandAnalog/ProductFamilies/CUB5.html These things are cheap and should do what you want. Most are either battery powered or will work with 12 volts DC. I never bought a volt or ammeter, but the counter/speed sensor CUB 5 is about $100. You will have to set it up, but that does not require a degree in electronics.
