Central IL | I wasn't sure if this should go here or in precision talk. I am using SMS basic and making RX's for my Nh3 toolbar. I am using a Pro 700 VT running a Raven ISO system on the toolbar. Do I need to make the rx as "Fertilizing Prescription (Dry)" and use lbs per acre or "Fertilizing Prescription (Liquid)" and use gallon per acre? Also, will my display show lbs per acre of total product or lbs per acre actual N? The way the book reads it will be actual N but the ISO screen says lbs per acre of NH3 so that is total product. TIA! | |
