SW Wisconsin | I have a McHale 995 wrapper that doesn't stop at the half tilt position when in the automatic mode. I have changed the magnet, checked for broken wires, switched sensors and even borrowed a control box from another person and it still goes full tilt which stops the rest of the functions from happening. When it goes full tilt you can not move the lever manually on the valve, I have to push the button on the controller back to manual to lower it. If I run it manually with the buttons everything works but it is very time consuming, I can also run it with the manual levers but that isn't much faster. The thing is making me pull my hair out, does anyone have any idea as what is wrong? | |
