| I control a 1903 with DC + an Integra. Do you have pneumatic valves? Your setup looks a little different than mine, but you should have air solenoids somewhere in the cab to wire into. I have left and right pneumatic butterfly valves, but they are controlled by hand levers, so I had to use an air activated switch that goes to the master wire. I also have 5 air solenoids for the 5 sections on the boom. I just wired directly to the solenoids in the cab, before the toggle switches. I am using a liquid control module and an aux input module. I am also using a raven harness adapter that plugs into the modules. |
