Eastern Nebraska | Going to your original question, just make sure that you recorded and documented all of the varieties properly at planting. Then when you're using Apex you need to go to Save and check Enterprise...etc...Variety Locator. It will create new VL files taht you need to save onto the card. You then need to Import the data into the 2630, then you need to set your display up for Harvest. When you do so, make sure that you have the proper field selected, then go into your documentation and set it up for harvest, hit change harvest settings and make sure VL is checked. | |
